rsten
The washer drain in my basement is an old 1-1/2" galvanized pipe. The flow rate of the pump in my new washing machine is much greater than the capacity of the old pipe, and a lot of water overflows. The old galvanized pipe is set with lead into the 3" drain below. I lack the skills to deal with something like that, and I'd rather not have to bring in a professional to fix it right now. (There's a bunch of related plumbing work that needs to be done and we're not quite ready to get into that just yet.)
Here's an idea for a workaround. I put a automatic utility pump into a 20 gallon tub next to the washer; drain the washer into the tub; and run a hose from the utility pump to the old drain pipe. The flow rate from the utility pump won't overwhelm the drain but will easily empty the tub in time for the next cycle.
I don't love it, but it seems like it would work. What do you think?
Thank you for your consideration.
Ray
Ray
