MikeG
I'm doing a bathroom remodel and replacing builder's the tub with a Kohler whirlpool tub. I have roughed in the plumbing to the p-trap. In a couple of weeks I'll be ready to set the tub in place. However, the overflow and drain fittings that I have (Kohler K-7166-AF ) looks like it needs a fitting between the drain fitting and the p-trap. Can someone explain or provide a link that explains that connection? I'm sure it is very easy.
Also, Kohler recommends either setting the tub in a mortar mix or using construction adhesive. Which is easier to work with and provides the best method of setting the tub?
Thanks, Mike
Thanks, Mike
