Vikram Desikan
I had my water heater replaced yesterday and one change that was done by the plumber was to vent the wh into another part of the chimney. If I'm not mistaken, there are 2 sections to the chimney. One for wood burning fireplaces (2) one for the the old boiler oil that was eventually replaced by the gas wh that was replaced yesterday.
My questions are-
1. Is it ok to vent the gas wh into the chimney which was/may be used to burn wood?
2. If ok, then what prevents the wh from venting out through my living room fireplace(located above)?
3. I live in new England where weather can be cold in Winters; should I be worried about the size of the chimney being an issue and cause backdrafts?
4. Should I call for a chimney inspection; will they be able to point out issues related to venting?
My questions are-
