SC Huzr
Hello, I was hopeful I can get some input on my project. I was basically planning to run all the vents up and tie them in together in the small attic space/drop ceiling area and hit an existing 2" vent line on the opposite wall from the proposed new toilet (currently exists due to the W/D that has since been moved). Is the attached too much or unnecessary or can the toilet be wet vented from either the shower or back to back sink (my studs are 2x4)? The set up will be a raised floor about 8" above the highest concrete step and then in the lower area the 3" drain line runs just inside the new wall . Final project will provide a laundry room on the left and a master bath on the right with a back to back sink set up for a utility sink in the garage.
