Hello,
I am having some challenges with my water pressure when I am demanding a higher amount of water. I have always been able to run 2 garden hoses at the same time with excellent water pressure and since recently installing a new pump (same kind as before) this has changed. I offer the following information on my system:
1/ Well depth is 272 feet. Just tested at 10 US gallons per minute.
2/ Grundfos 1 HP submersible pump.
3/ Square D 40/60 pressure switch.
4/ Well Mate WM20 Pressure Tank (with bladder)
5/ System has a good pressure guage in-line just before the pressure tank.
When the water demand is "not" higher the pressure switch properly kicks in at 40 lbs, builds up pressure and switches off at 60 lbs.
When the water demand is higher the pressure switch does kick in at 40 lbs but the pressure will drop to around 20 lbs until the demand eases up. This would never happen before, as even with "more than" 2 garden hoses running at once it would always build pressure back up to 60 lbs after the switch would kick in at 40 lbs.
My pressure tank is set at approximately 39 lbs pressure but I am not 100% certain my hand guage that I checked it with is completely accurate (I have a feeling it could be out by as much as 4 or 5 lbs which could be causing the problem). Is there any way to calibrate my hand guage somehow to ensure it's accuracy... perhaps with the in-line guage on the system that I know is accurate?
There was some "fine" sand coming through my system before the pump was replaced but I have an in-line filter (located after the pressure tank) that would catch it. There is no sign of sand since the new pump has been installed, but perhaps there is some previous sand build-up in the check valves or somewhere else restricting water flow? I do know that the pump does not have any sand getting into the intake area any more, as I had to bring it up after 6 weeks due to a manufacturer's defect whereby they replaced the pump free of charge.
The system was installed about 9 1/2 years ago and I was told that my pressure tank may fail at about this age, but there is no sign of water above the bladder and no water vapour comes out of the air valve if I am letting air out. Is it possible that there could be a "slight" failure in the pressure tank and it is on it's way out or is this something that would immediately happen and shut down the system completely? If a pin-hole leak is possible perhaps I should just replace my pressure tank and this will correct my problem?
Thanks in advance for any assistance / recommendation anyone can provide. This is a great forum by the way and I am sure glad I found it!
