Un-shielded fernco couplings
Kevinjm4
Snoqualmie, WA
this is where I wish I had the experience to know if I’m good to move on with my project or make the correction now... with fernco un-shielded couplings (see attached photo), is there a rule of thumb for the amount of deflection allowed. I have a coupling joint where there are a few degrees of deflection from one straight pipe to the other straight pipe... not sure if I’m saying that right. Please ask for clarification if there’s confusion.
It’s not anywhere near extreme but there is some.
With normal fittings is it the case you are allowed a 5degree tolerance In any direction? Does the same go for fernco’s?
I think fernco says zero deflection allowed, but of course they do. Looking for a plumbers take here...
Any advice? Thanks!
wwhitney
Berkeley, CA
Just confirming that you know the unshielded type is only for underground use, above ground use requires a shielded coupling.
Cheers, Wayne
FullySprinklered
Georgia
The shielded ferncos can be awkward to use in some situations since it has a stop in the middle of it. The unshielded fitting can be slid down the pipe, then slid back over the joint to be tightened down. I'll let others debate the legalities.
