Tub spout connection
Jetboy55
Wisconsin
I have a old Delta tub spout right now. It unscrews and what I see is a fitting sweated to the pipe. The fitting is threaded near the wall, but also has a o- ring about an inch further (away from the wall). The spout has threads right at the wall end. What kind of connection is this called? I've seen names like "1/2 NPT" , "3/4 NPT" , "1/2 male pipe" , "1/2 male threaded" , "3/4 make threaded". It's making it hard to find a new replacement, I don't really want to sweat a new connection or change the connection type. Thanks
Delta diverter... close...
quick notes:
Delta Faucet RP17454 Tub Spout Pull-Down Diverter, Chrome
(RP17453 is same but plastic) RP5836 similar but adapter RP33794 has set screw.(confirmed)
https://www.deltafaucet.com/parts-product-detail?modelNumber=RP33794 is the setscrew adapter.
It may sit closer to the wall than the one I have.
Very nice system. Many spouts available.
Product Details for the Delta RP17454
6" Tub Spout Diverter Replacement Part
Jetboy55
Wisconsin
The RP33794 looks exactly like what is on my pipe currently. Sorry no pictures, I haven't been home yet today.
Jetboy55
Wisconsin
I'm hoping to get a after market spout because Delta spouts in black are so expensive. That's why I want to understand the size and nomenclature of the Delta adapter that is on my pipe. After further research I think it is 1/2 NPS, sound right?
Jetboy55
Wisconsin
Yes I have, in fact I painted my Delta shower trim that was chrome originally. Used a sealer after the paint. I don't know how long it will hold up, but it looks good now. Was going to replace the spout, thinking it wouldn't cost much, but if I paint the one I gave, I guess it might be better, because I'll be able to keep the Delta pull down that I have, which works really well.
Right, if not soldered. If the galvanized nipple comes loose, use a brass nipple with the new spout.
Those Delta spouts make it easy to get the distance from the wall just right. With some spouts, you might have to make a custom length nipple. Others you screw in a piece of copper pipe with a MIP adapter, slide the new spout into place, and tighten a set screw.
