Tried replacing my leaking shutoff valve
Jose1983
California
I replaced my leaking shut off valve that supplies water to the restroom sink faucet. What kind of water pipe is this????? It looked aluminum in color. It also looks like PEX. I’m just a Homeowner trying to figure it out. Thanks
It looks like a compression valve over PEX. There was an insert in the PEX so that you could use the compression valve. You may be able to put on a new compression valve, using the old nut, ferrule, and insert.
