thisnameiscreative
Hello! We're currently looking for a water treatment for our house that uses well water, and I've been reading this forum and learning lots about different treatment systems. Thank you!
We had a couple of people come out to test our water and give quotes. Below is the info we got on the water (range due to different people telling us different things):
Hardness: 15 - 20
Iron: 1 - 1.5 PPM
TDS: 450 ppm
It's a 4 bedroom house, but there will be only two people in the house most of the time.
Right now we're deciding between two softeners, both with 32,000 grain capacity:
Evolve EVR (http://www.evolveseries.com/wp-cont...Softener-Spec-Sheet-LIT-EV-SOFT-SPE-11-17.pdf)
Clack WS1 single tank on demand system
The Evolve EVR also uses a Clack valve, but what we like about the EVR is that it only use around 30 gallons water during each regeneration (thus half the amount of salt required compared to the Clack). Price wise there isn't a significant difference for it to affect our decision.
I've browsed the internet to find out more information on the Evolve EVR, but I can hardly find any consumer information on it. My question to you all is - which softener would you recommend? The EVR does have better/longer warranty on both parts and labor, but could I safely assume I don't need to worry too much about servicing Clack products?
My other question is, should I get an iron cartridge filter on top of the water softener? One of the companies we got a quote from recommended the filter. The iron content in my water is not too high, so the clack valve may be adequate. I'm just curious how much having an iron filter will improve the lifespan of the water softener based on my current water conditions. I got a quote for filter/cartridge installation at $550 (for Pentair Pentek RFFE10-BB and RFFE20-BB). Is that reasonable?
On top of the softener, my spouse really wants a whole house carbon filter. We may go with the Fleck 5600SXT (1.5 cubic ft) unless you have other recommendations and/or if you, like me, don't think we need one.
Thank you!
Hardness: 15 - 20
Iron: 1 - 1.5 PPM
TDS: 450 ppm
Thank you!
