Toilet tank water looks shiny
H22lude
Rhode Island
I'm on a well with no filtration system. The water seems to be pretty clean but all the water sitting in the toilet tanks have a shine to the top of it. What could cause this?
Water test if this helps
Color - Apparent....0
Turbidity................0.160
Odor - TON............0
pH...........................5.54
Calcium Hardness as CaCO3......5.17
Chloride.......................................4.45
Chlorine - Total Hardness...........<.05
Nitrate as N.................................0.256
Nitrite as N..................................<.01
Sulfate as SO4..............................6.61
Calcium...............2.07
Manganese..........0.0403
Iron......................<.05
Sodium.................3.66
Total Coliform.....absent
E-Coli...................absent
That is the biggie. Make sure that does not go through metal pipes.
Manganese..........0.0403 is just below where they think might cause a taste problem.
Regarding the shine on the water, is that 2 hours after you flushed the toilet, or two weeks?
Banjo Bud
Active Member
South Carolina
Yeah that PH is really low. Which means your water is high acid. That’ll eat a copper pipe in no time. If you get blueish greenish rings in your toilet, that’s copper residue. You can get a tank to treat it but then your water hardness goes up. So then you need a softener. It’s a scam. Lol. I guess I didn’t answer your question about the shiny water. I have no idea on that.
It is possible to inject potassium hydroxide solution in a metered way to neutralize, and that does not raise the hardness.
H22lude
Rhode Island
I believe the only metal pipes are the ones connected to the pressure tank. After the tank is all PEX. I do want to get a pH neutralizer to raise the pH.
I'm not sure on the time frame of the shine. I will use a toilet and then check after a few hours to see if it is there.
Edit: Maybe the pipes connected to the shower valves are copper? I don't see any green or blue stains anywhere yet.
No copper that I know of. All PEX expect for a few pipes attached to the pressure tank.
Yeah my hardness will go up but my water is really soft without a filter so I think it should be ok. If I does increase it a lot and I wouldn't be opposed to a softener. Obviously more money but as long as my water is good, I'm ok with spending the money upfront.
