Toilet flange too high
Galerie
Maryland
As you can see the toilet flange is too high, I am remodeling my bathroom and want the flange lower, if you notice in the pictures, there is some sort of soft stuff between the flange/closet and the pipe going down. The stuff on top of the flange is hard. Is there any way I could remove this and put in another closet/toilet flange that I could lower.
Jimbo
San Diego, CA
It is often possible to lower the flange. It may or may not be easy...depends on what the parts are made of...cast iron/lead/plastic/etc. and how they were put together, as to whether there is any wiggle room.
Cacher_Chick
Test, Don't Guess!
You need a new flange, which should not be set until the floor is done. Drill & pull the lead out and the flange will come off. Get a new flange and lead it back in on top of the finished floor, then cut the excess pipe off the top.
Gary Swart
Yakima, WA
That flange is pretty well shot anyway. Leading a new flange is the right way to go, but that is a job for a plumber. It won't take him long.
