Candy Palms
Hi Everyone,
First post, hopefully can get some opinions. We recently got a home with an older Aquabrass shower set.
No matter which way we turn, it only gives hot water, the adjustment is not working no matter what we do. (all other showers in the home was fine, not the same model but from Aquabrass).
A note that our contractor has replaced all the plumbing pipes when we moved in, as we have Kitec pipes which is a risk of leakage (another story). The hot water tank was in vacation mode before we moved in, so the contractor never tested the temperature, and now all the walls are closed and tiled.
Our contractor said there is something wrong with the mixing valve, but just want to check with the experts here to see if this is the likely cause. We tried getting a replacement valve but they don't make it any more. So like to find out it could be something else, we don't want to tear everything apart all over again..
Appreciate your input!
