vdotmatrix
I installed a bypass on my water heater in 2004 with flex copper lines so i could do maintenance on the WH and not have to shut off water to the entire house.
The bypass makes this a non rigid system attached by the flex curley lines....really handy when i replaced the wh a month ago.
I just replaced the water heater and i sometimes find water in the bucket under the safety valve next to the water heater... i need to install a THERMAL EXPANSION TANK.
I bought one from Lowes (2gallon).
So no room anywhere for this thing and i thought if i could find a TEE to branch off the end of the cold water FLEX supply in the 3rd image, i could put the tank above the WH....the expansion tank would only be isolated whenever i would drain the WH twice a year .
The tee needs to be 3/4” female 3/4” male and the branch could be a 3/4” push fit...
Do they make such an animal..
Does this sound like a plan?
Thanks in advance.
