Testing Drain Lines
Kurt23
Centralia,WA
On my list of things to do from the inspector was to test my drain lines. I have plugged my shower drain, toilet, kitchen, and bathroom sink with mechanical wingnut test plugs. The outside clean out will be plugged with an inflatable rubber test ball plug. I will then fill the lines with water. The instructions from Cherne say to relieve back pressure before deflating plug. How is that possible?
Photo added by Terry
Possible to follow that instruction? Just don't remove the Cherne test ball first. However in practice, I would recognize that water will come out somewhere. Decide where you want that to be. If that place is outside, then I would just ignore that Cherne instruction. I am not a plumber.
Kurt23
Centralia,WA
Okay. Just going to go with deflate the balloon while under pressure. I could attach the chain it comes with to something in case it wants to go down the drain. I wonder how common hand pumps are that have a psi reading and are able to hold and release the pressure at the hand pump? Going to go check Wally World. I might end up getting the product you posted Terry. That is exactly what i needed. Thanks
Cacher_Chick
Test, Don't Guess!
A couple of years ago I had a 4" plug blow out of the vent stack like a cannon firing. When it fell back down from the sky, it hit hard enough to cut a gash in a shingle on the roof. I stick with the test ball now.
Is the test ball holding back water or air? I had been presuming water, but I think cacher_chick was using air.
Kurt23
Centralia,WA
Thanks for the additional responses. I am testing with water. I ended up just sticking the smaller rubber test ball in the outside clean out. I found 5 small leaks so tomorrow I will be cutting them out and replacing. I thought that was pretty pathetic but there were a lot of other joints that could of been leaking. When I released the test plug it was like a geyser and I got soaked even with the air hose extension.
