Tankless Venting Question
Steve Soldo
Pasadena, CA
Replacing an Bosch Aquastar with a Navien condensing unit, indoors. Previous system had a 5 inch exhaust galvanized ducting.
I can run the 2 inch exhaust line PVC through the existing 5 inch duct. But I am not sure how to secure the PVC as it travels through there, especially at the roof.
Any ideas how to do this ?
Fitter30
Peace valley missouri
What's the full navian model most need fresh air also. Two 5" sheet metal caps, in plumbing a 2" Pipe hanger and a tube of polyurethane caulk. After the bottom cap to flue by offsetting the hole for pvc to the out side edge with the 2" pipe hanger think you could catch the pvc with hanger attached to the flue pipe after ell (90°). On the roof could center the pvc center of the other flue cap. Use the poly caulk to seal everything. Caulk is little messy but I've had good luck using it. If pipe at the flue isn't plumb can use a hair drier to straighten it just watch the heat. Could also put some insulation between the pipes.
www.homedepot.com/p/The-Plumber-s-Choice-2-in-DWV-Pipe-Hanger-in-Galvanized-Steel-02HDWP/309604114
Steve Soldo
Pasadena, CA
Well, this unit is very expensive and I probably should vent it by the book. I am not so much concerned about the air inlet, but rather the exhaust. I am going to pass the 2" PVC through the existing vent pipe. But I have to figure out a way to secure the pipe and also seal around the pipe at the roof.
Bannerman
Ontario, Canada
A gas burning appliance requires sufficient air for combustion, and as most residential tankless WHs consume as much as 199,000 BTU/hr, the combustion air requirement can be substantial.
If the tankless unit is located within the home's conditioned space, unless provision is made to supply combustion air from an external source, it will likely be consuming conditioned air from within the home, thereby resulting in increased discomfort due to drafts, while also needlessly adding to the monthly heating or cooling expense.
might find a stock item some where but fabricating a funnel type fitting should be easy enough for your self or a tin knocker for the 5 x 2 reducer
Rrm8711
CO
Greetings
I have a similar challenge with a Takagi 310.
Current flue from a previous Takagi T-K3 install is 6” galvanized.
Takagi wants 4” on the 310 model, so I’m thinking 4” stainless steel flue up through the 6” galvanized and anchor it at the top.
Thx
Greetings
Thx
sure why not ? Hearing differant things no Idea if the Tech support guys or gals have a brain or not but they havent helped drewski solve a thing. Thier paper work says not to oversize vents but they only seem intersted in whether its blocked in fairness the issue might have nothing to do with venting
