adjacent
Hello,
We currently have a 12-year old 50G natural gas water heater that is still working, but performing less week than before.
We have been considering replacing it for improved performance, and would love advice from this knowledgeable community. The main reasons for the upgrade are: a big 98 gallon tub we don't really use since we can't fill it with hot water (my wife has mentioned this to me for 12 years) and two young daughters who will be teenagers soon and I anticipate the need for more hot water for our family of four to maintain happiness during morning getting-ready routines.
Cost is not a huge issue, as we are thinking this is more a long-term investment for better performance over our lives in this house. There is though a limitation on size - the space for the water heater is about 26" wide and 29" deep. Current water heater is about 57" tall and fits with no problems, but the space prevents us from going to a 75 or 100g conventional WH. There's a bit more leeway space above it for venting, pipes, and an existing recirculation pump, so a new one could be a little taller. Our home does have a NG stove, furnace, dryer, and fireplace (rarely used), and have no tmeasured the output at the 1/2" valve near the existing WH so don't yet know what it could handle. The gas meter is about 25' feet from the WH so we could run a dedicated, larger pipe without a huge amount of trouble beyond the cost.
A few things I have been considering:
(1) An a thermostatic mixing valve - we've already turned up the temp of the existing WH, but this might allow us to turn it up more while maintaining safety - since our current WH is still working. Should be pretty inexpensive to have a plumber do this but how effective?
(2) Replace existing with a new 50g, but newer one. It'd have same performance specs but perhaps be a bit better since it's newer and would have no deposits. This seems relatively cheap to do plus would come with the mixing valve.
(3) Replace with 11.1GPM tankless. This will be expensive since it requires different venting as well as likely a more robust gas line routed directly to the tankless. Benefits are infinite hot water, but I've read about the many drawbacks and complaints of tankless (flow rate, maintenance, descaling, noise of unit, noise of pipes) so not sure if that's a good idea. It would be nice to have the space back in the garage since our garage is small.
(4) Replace with stainless commercial. I've just learned through reading on this form that this may Be an option but don't know too much about them. Apparently they would have higher BTU capabilities so they could be comparable to size of my existing water heater but perform much better (e.g., better recovery rate, low maintenance)? It sounds like then I'd still need an upgraded gas line. Are most installers familiar with installing stainless? None I've talked to have suggested them. Can a commercial unit be installed in residential? Any other drawbacks or concerns, beyond cost?
I would welcome hearing any recommendations you have. Thank you for your help!
