Larry Blsair
Couldn't figure out where to put this thread so since I have a tankless heat system decided here.
I have a TACO 007 feeding a tankless heater and then the water goes back to a 40 gal tank. It ran great last season but when I turned it on this year the pump seems to have quit. Took the pump apart and it is running though I think is isn't turning very fast. Not 3700 rpm as the face plate claims. Took the pump over to the sink and set it up to pump water from the sink back to the sink so there is 0 head on it. It is probably pumping 1 cup a minute.
I had an old 007 that the pump shaft had broken so I took the cartridge out of the newer pump and put in it and the old housing - same thing - very little water. I suppose that the cartridge is toast. The housing gets really hot if left on for 5 minutes or so. The impeller is turning and there is water in the pump but no throughput.
Is the 007 big enough to feed a tankless heater. All the pipe in and out is 3/4 copper. About 5 ft of copper out of the tank to the pump and then to the heater and the same from the heater back to the tank. The system is pressurized to 18-20 psi.
Another question - what is the deal with the price of cartridges? You would think they were tied to the cost of gun ammo I can buy a complete new pump for $10 more than the cartridge. Just wondering.
Thanks for any thoughts
Larry
Larry
