Verywellfl
Welled out by now..( see my other posts)... New well is finally drilled, new trench and pipes are connected to new pump, new tank. Still same issue - no water! Ex says priming fails (again) and now wants to put t-valve between well head and pipe. I've never seen a valve between well head and pipe..its always a upside down u- shape pipe connection, then maybe followed by a valve. .could a t- valve fix the (priming) issue?
PS: after spending thousands of dollars I m afraid that ex didn't hook up new pump correctly in the first place...same issue with old well than with new well...
To sum up:
T- valve between well head and underground water line?
Ok? Irrelevant? Might fix priming issue?
Thank you in advance!!❤️
To sum up:
