Super multi head system shower and loops
Rick Lithgow
Pittsburgh
So we're building a large shower (5x7). Facing the shower on the right is a
MOEN S3371
DNRP 3/4" ROUGH-IN EXACTTEMP
THERMOSTATIC PRESSURE BALANCING control and 4 volume controls (shower head, rain shower, body sprays, wand).
On the left is the same Moen s3371 and 2 volume controls (shower head, body sprays)
I have built the loops for the body sprays and a manifold for everything else. My question is feed. The shower is being fed from 3/4" lines (branched off from the house inbound line and the water heater before it hits our PEX manifold. The house is being fed by a 1" line from the street)
Should I simply split the hot/cold lines to each thermostatic control, or should I build a balance loop with one entry and 2 exits (one for hot, one for cold where each exit goes to a thermostatic control) to maintain pressure? Overall pressure for the house is around 70-75 psi and the vertical height from the branch offs in the basement are about 13' up.
Attached is a pic of the one side (I've since done more plumbing)
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I am not much help with how to plumb it, but that won't matter if you don't have enough water available. Look at the GPM requirement for the shower. If the shower requires say 18 GPM, and the feed cannot supply that much, extra loops and stuff won't help. Insert fittings in 3/4 PEX make it more like 1/2" copper. You just can't get much water through 1/2" pipe. Larger pipe will help, but you still may need more supply. I have helped with these before where we had to set up a small cistern or storage tank with a booster pump to supply enough for the shower.
Marlinman
Jacksonville Florida
Look at this Moen literature. About 1/3 down you will see "ExactTemp". This shows the correct piping for the accessories you want.
index.php
Rick Lithgow
Pittsburgh
No problem in the initial plumbing (and plenty of volume and pressure) But my thought is loops to split the other side...
