Sump Pump vent hole spray help
WeezerNY
Michigan
Hi all,
The switch on my Zoeller M53 was acting up and I was saved by my city water backup system. I have a fairly crowded sump pit with the sump pump, guardian water backup, and a large radon pipe. As I am not the original home owner I have no idea how old the pump is so I just replaced the whole thing.
The pit itself was full of probably decades of rust rocks and junk, cleaned it all out, installed a new M63 (supposedly updated M53 with cast impeller and better switch) with all new PVC, Zoeller quiet check valve, etc. As per the forums and the Zoeller instructions I drilled a 3/16 vent hole at a 45 degree angle in the bottom pipe, about 6 inches above the pump.
So after all this I was quite proud of myself. The pump and the water backup work great. However, the pressure coming out of the vent hole is such that it is hitting the wall and I am getting spray coming up out of the pit.
Any suggestion? Do I try to patch that hole and drill a new one at a sharper angle? Can I put some kind of hood that will direct the flow and limit splash from the side wall? The quiet valve uses a union joint so I cant just try a new piece of PVC with a fresh hole without wasting the whole valve.
I am fairly limited on how much I can move the pump itself due to the other stuff already in the pit.
Put a square piece of rubber, or even a curved piece of hose, over the hole with a hose clamp on the end to act as a hinge. It will direct the spray downwards without compromising the function of the hole.
WeezerNY
Michigan
Thanks for the reply, having trouble visualizing what you are saying.
Essentially just affix some rubber to the pipe, snug at the top and loose at the bottom, so it works kind of like one of these? How would I attach a curved piece of hose?
A single worm gear clamp at the top of the piece, I would think.
Split the hose longitudinally (axially).
Treeman
Active Member
Michigan
Square piece of rubber means something like a thin piece of tire inner tube.
Or, you could buy the appropriate size Fernco fitting. Slice it open vertically to slip it over the pipe and secure the top with the hose clamp. The spray will shoot out, hit the rubber "umbrella" and drop straight down. You don't need the lower clamp.
WeezerNY
Michigan
Ah thats a great idea thanks!
WeezerNY
Michigan
worked like a champ thanks! Used a 1.5 to 3 inch.
Bert Lee
Central, NY
I know this is an older thread but I wanted to thank everyone for this idea. I stumbled on this thread and it was exactly what I needed. Simple, cheap, easy and very effective! It has quieted the crazy loud frantic spray to something closer to a toilet tank filling and controls the unwelcome spray and splashing. I cut this in half to test, and I knoe the original idea was to simply split but the I think the metal arm is a bit in the way to accommodate the full round version. May tweak a bit but this is beautiful. Not seen the idea anywhere else. Thank you.
https://youtu.be/gu4PhGnoAAs
