Hi all,
The switch on my Zoeller M53 was acting up and I was saved by my city water backup system. I have a fairly crowded sump pit with the sump pump, guardian water backup, and a large radon pipe. As I am not the original home owner I have no idea how old the pump is so I just replaced the whole thing.
The pit itself was full of probably decades of rust rocks and junk, cleaned it all out, installed a new M63 (supposedly updated M53 with cast impeller and better switch) with all new PVC, Zoeller quiet check valve, etc. As per the forums and the Zoeller instructions I drilled a 3/16 vent hole at a 45 degree angle in the bottom pipe, about 6 inches above the pump.
So after all this I was quite proud of myself. The pump and the water backup work great. However, the pressure coming out of the vent hole is such that it is hitting the wall and I am getting spray coming up out of the pit.
Any suggestion? Do I try to patch that hole and drill a new one at a sharper angle? Can I put some kind of hood that will direct the flow and limit splash from the side wall? The quiet valve uses a union joint so I cant just try a new piece of PVC with a fresh hole without wasting the whole valve.
I am fairly limited on how much I can move the pump itself due to the other stuff already in the pit.
