groundwater
Hello experts! I moved into a home recently and have noticed one of the two sump pumps runs rather frequently. Goes for about 10 seconds every 10 minutes or so, maybe more frequently if it is raining. The builder had to raise the basement level 2 feet due to a high water table but my main concern is the way the window well drain was installed.
It has two openings for the intake pipes (corrugated black pipe) at 90 degrees that look like were manufactured into the basin. However, there is a third opening for the window well drain (PVC) that was very roughly cut out. I've tried to draw it out in the attached picture
The pump turns on when the water level is about 1/3rd of the way up the window well pipe. It pumps the water down, well below the window well drain, and then shuts off. However, as soon as the water level drops, the window well pipe drains as well as water that comes gushing in through the rough cutout. Within 10 seconds or so the water level is about 1/4 of the way up the window well pipe again.
To me it seems like this isn't ideal. Should I try and seal up the rough opening around the window well pipe? I'm not sure the pipe could be raised any due to the required slope. My other thought was getting a deeper basin but then I may just be pumping out more of the water table.
I do have two sumps, one in the corner of the house with the windows well that runs frequently and the other is on the opposite side of the house. I've never heard it run, but have verified it is functional. I've also recently purchase a battery-run pump as a backup but have yet to install it yet.
I appreciate any of your thoughts.
