Submersible loses volume and pressure
lazer3691
I have an 85' well with a 1/2hp submersible about 14 years old. Static water level about 25'. It has been great for doing my irrigation and domestic until this year.
Now, it works good for my domestic water needs but when I use it for irrigation I suddenly have a problem. When it starts it works fine, but after about 5-10 minutes it dies down and looses pressure and volume. The sprinklers start surging and th pump sounds noisy. Then I have to shut it off to recover.
I've resized my sprinkler nozzles down to a 6-8gpm consumption, and now i can go about 20min before the problem starts again.
Any ideas on where to start?:confused:
Thank you in advance.......
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
It probably happened gradually. If the static water level is still the same, the perforations or screen is clogging up. Screens usually clog gradually. You just don't see it until one day the well is only making 7 GPM, while you are trying to use 8 GPM.
lazer3691
Forgive me for asking a dumb question. :confused:
But is the screen on the pump, or the casing? Is it easily cleaned or replaced?
Is this a job for a pro?
Sammyhydro11
Massachusetts
Who says the guy has a screened well? Screened wells only need to be placed at 15 to 20 feet beyond the static water level depending on the porosity of the water bearing material. I would bet the guy has an artesian well (slang around here for rock bored well). If that's the case i would consider hydro fracturing the well. Not a job for a DIY!
sammy
www.tylerwellandpump.com
