Currently I have a well 375' from the house. It is supplied via it's own meter from the elect. co. The entire electrical system is about to be condemmed. The overheads run through trees etc. I also need to replace the piping from the pump to the house.
Getting rid of the meter will save me $180 per year in facility fees.
The pump is a 1/2hp 110v. I plan on replacing it with a 220V 3/4 hp next summer.
I need to install the new piping now so plan on running new electrical wiring now as well, while I have the trencher. So the pump will run off the house's electrical service eliminating all other wiring to the pump. I have a new 200 amp service at the house.
With a 3/4hp 220v pump I can use #12 as it goes 480'. I will use a breaker box at the pump as well as a disconnect.
Is there any economical options to use the existing pump on the new wiring? It is too long a run for 110v using #12. I would have to go #6 but the price is out of sight.
I will be using UF cable and burying it 36" down. What is the proper way to permanently splice underground? Can I use crimp sleeves and epoxy filled heat shrink? Or do I have to try and find one run of wire? I'm rural so don't have the options of the big city.
