Dear friends
I got a problem I don't know if you can help me..
The water mains pressure is low and I have fixed a booster pump with a pressure tank and a pressure switch
My target is that when I open the water tap I want to have a STEADY reasonable pressure but the present situation is that when the pump cuts in I get a momentary hiccup which results in a change of the proportions and mixing of hot water to cold water when I have a shower and that results in having shocks of cold mixture or hot mixture during the shower AT EACH TIME THE PUMP CUTS IN , very annoying
Do you have any idea how to maintain a steady pressure from that system?
Or at least fix something to make the pump runs as soon as you open any water tap , because as long as the pump is running the water pressure is steady
Thank you very very much in advance for your time and help
Bob
Bob
