Solar Hot Water Stainless Steel Tank size
rollandriives
San Jose California
why are the tanks only 120 Gallons? some code rule? why can they not be bigger? as i find with solar Hot water more storage is better! what im trying to make for better solar hot water recovery but i would like to get a bigger tank made
and where can i buy a drain back tank?
WorthFlorida
6th clinical trail chemotherapy 5/15/24
Solutions
Orlando, Florida
Common sence and more is not always better. First it's the weight. 119 gallons of water is 992lbs, plus the weight of the tank. Then you need a floor that can support thatvweight. Physical size is another. You need to be able to lift and move the empty tank through door ways and stairs such as for a basement location. 120 gallon for domestic use is more than needed. To go larger would be commercial application, therefore, most installations 120 gallon works. Being in California you probably need to install as a water heater to meet seismic codes. Adding a second tank is your other option.
Fitter30
Peace valley missouri
Wouldn't doubt lead time for a tank builder is a year or better and the cost $$$$$. Drain down tank probably a electric water heater. Already insulated, hot connection vent, cold drain down and drain for pump refill. Using vacuum tubes? Boiler grade glycol and 1/2" or 3/4" boiler air vents.
