mf915
Thinking of getting Fleck 5600SXT. Location will be in the semi-basement. There are no drain pipes close by. So i think i will have to drill a hole in the concrete block and run a PVC outside. The drain location will be a few feet up (ceiling of semi-basement) and maybe 10 ft across where the concrete blocks are.
1) what size of the PVC should i use for the drain ? would 3/4" be okay ?
2) would i need a p-trap before the PVC exits the concrete block ?
3) during winter, basement can be below freezing point. Since the drain hose will need to go a few feet up and across before exiting, how do i prevent it from freezing ?
