Smelly Shower Drain
Evan Jaffe
I have a standalone non tub shower that routinely smells. There is never any standing water on the shower floor itself. I unscrewed the drain cleaned it out there was some hair and dirt. There then was a little bit of water below the drain so I poured some bleach in it and it seemed clean or just didn't smell.
After a day or so, the smell returned. Is there supposed to be water below the drain in the pipe and if so how much? Or do I have to pour Drano in there etc.
Thanks!!
WorthFlorida
Solutions
Orlando, 32828
Don't use Drano! Save your money. Yes, there must be water at the bottom of the drain in the P-Trap. It's the water that keeps the sewer gas from entering the room.
Do you use the shower every day or the odor returns after a few days of non use?
When the odor returns is there water at the bottom of the drain, just lower or about the same?
Is this a new install, or and old one where this problem just started?
Is the pipe PVC or iron?
For some reason the water level is dropping. Causes could be a few things, one is there is not enough venting and if a large volume of water drains, a suction is created behind the flowing water and it pulls some of the water out of the trap. Usually when there is little use of a sink or shower drain, the water can evaporate but this is probably not your problem. If this is on a slab the p-trap could be leaking into the ground. Just google "how does a p trap work" and you'll find plenty of information.
Evan Jaffe
To answer your question:
The shower is used about twice a day. When the odor returns the water level seems to be at the same level.
It is not a new install, shower is about 5 years old. This problem has existed for at least 1 year. The pipe I believe is PVC. This shower is located on the 2nd level of our house.
