Wade G
I've got a Kenmore dishwasher that smells like rotten food after washes and leaves dirty water in the bottom portion (not lot, but some). I've searched the forums and investigated my own hookup, and looks like it was done incorrectly (See attached picture). The dishwasher drains right into a metal tee waste pipe after the P trap and barely loops up. I assume this is causing either some siphoning, and then allowing gas back into the house (since I'm behind the P trap) or something is causing the washer to not properly drain at all initially and leaving some dirty water behind.
One professional said simply rerouting the dishwasher drain line much higher and then towards the disposal, then capping that tee would solve my problems. A second quote told me due to that metal pipe, I don't have much hope in solving my problem even if I rerouted.
Does the pipe being old and metal really have that much to do with it? Or can I just do as the first professional mentioned? If so, what can I cap it with? I don't know the size, material, or anything else. Perhaps just a pipe cap with the right diameter if its threaded? Thanks!
Side note: I know I need to get rid of that flex tube. I'm trying to mentally reroute the pipes now to work. Let me know if you have any ideas for that, I'm not a pro!
