Sliding door leaking water into basement
hasraa
Hey all,
I have a glass sliding door which is leaking water into the basement ceiling below. I was planning on fixing the leak by opening up an access panel in the basement, running some water along the door, and applying some caulk onto the leaking area with a brake line from below, but I am not entirely sure that this is the best way to fix it. Another method I was thinking about was shining a flashlight through the access panel in the basement and looking at it from above to see which areas have gaps in them, then filling it in with caulk from the top and below.
I was wondering if anyone has had the same experience and how they went about finding the leaking seam and fixing it, any inputs/thoughts would be appreciated.
Thanks,
Hey all,
Thanks,
To fix the leak in your glass sliding door, first, check for cracks or gaps in the door frame and bottom track. You can run water along the door while someone watches from below to find where it leaks. Use a flashlight to look for gaps through the basement access panel and mark them. Apply waterproof caulk from both above and below, making sure to clean the area first. Adding weatherstripping can also help. If the leak continues, consider calling a professional for help. Good luck with the repair!
