Hello all.
I am a novice to plumbing so please bear with me. Recently moved into a new home and of course shower is not nearly hot enough because of the default anti-scald setting. I took apart the handle to adjust, but was greeted by a mechanism unlike one I’ve seen before.
The most info I have on model/make is that it is a “Freendo”. It seems that the usual plastic stopper is buried underneath the metal casing, so it is impossible to take out and/or turn. It will not pull out or twist out. The center brass piece is also seemingly non-removable. The best I could do was remove the outer nickel plate and the outer nickel casing. I have scoured the Internet for any sort of manual or how-to video on how to work with this particular model, but no luck.
Hopefully I am missing something obvious. If anyone knows how to get this thing adjusted or can offer any advice, that would be greatly, greatly appreciated.
