Shower & Tub Rough Valve - What length for Threaded Pipe for Spout?
cloves
New Jersey
Hi guys,
Currently installing a Phister 0x8 shower and tub valve. I am also using a Phister universal trim kit. With this trim kit I can use either copper or threaded pipe as it comes with adapters.
I was going to use a brass threaded pipe (both ends) on the 90 drop ear. I can't seem to find an answer to what the length of the threaded pipe should be. The instructions from Phister don't give a length. Is using the threaded pipe version the best bet? I attached a picture of the page with the 3 options from the instructions.
The length is determined by how far in the wall the drop ear ell is and how far it has to stick out for the spout thread. There is no "recommended" length. It is determined by measuring WHEN you get ready to install the spout. You will probably have better luck using two brass nipples and a brass coupling, rather than a single brass nipple.
Asktom
Victor, MT
Assuming the wall is open, you can use a galvanized nipple long enough to poke out of the wall for now, and switch to brass when you put on the trim. You will be able to get a measurement at that time.
Gary Swart
Yakima, WA
Why not use two threaded adapters with a copper pipe cut to the exact length you need sweated into the adapters?
Bill Shack
30years plumbing 10years plumbing inspector
Montreal Quebec Canada
I always installed a piece of copper about six inches long with a male adapter solder on to it, then tightened on the the connection inside the wall which was a drop ear male x female 90. This covered all the bases i could unscrew and go with thread nipples or slip on or any other thing that might come. I learned that customer will change their minds and could leave you up the creek.
Asktom
Victor, MT
A brass nipple (or two of them and a coupling for more adjustment) is the strongest and least apt to cause complications in the future if the length needs to be changed. The two male adapters and a chunk of copper will probably save you a trip(s) to the store to get the correct nipple(s). One male adapter and a piece of copper and a slip-fit spout is the easiest way. I like brass nipples because you don't have to hope the male adapter in the wall unscrews before the solder joint comes apart if it ever needs to be removed. Some folks use a CC drop ear 90 and a slip fit spout but, coming from the world of repair plumbing, I find that "wham bam".
cloves
New Jersey
THanks for all the replies so far guys!
asktom, your setup sounds interesting. Any chance you have a photo floating around?
Assuming the big box store is going to carry the brass double threaded pipes right? I didn't see at home depot last time I went.
cloves
New Jersey
So I have been working on trying to get this to work today. I went to the big box store and picked up 2 brass 1/2 pipes, one at four inches and one at 6 inches. With the extension in the kit I was able to get the bath tub spout to align with what my finished wall would look like. But its so hit or miss because when you spin and are aligned perfectly up and down, you may not be touching the tiling.
Seems very challenging and I am considering just getting the copper male end and soldering it onto a piece of pipe a few inches long and using step labeled number 13. The spout gets a plastic cartridge inserted. Then the cartridge and spout get pushed onto the copper stub pipe. There is an o-ring that tightens over the copper pipe. This is what you guys referred to as "slip-fit" right?
Any pros and cons to going for step 13? I think this is what Bill is referring.
quote; I didn't see at home depot last time I went.
You did not look in the right place. They are on the rack with all the copper compression fittings.
