Tanner
Hi everyone,
I have a basement bathroom with an old tile shower that had been improperly installed and was moldy and falling apart. I tore it out to the studs 2 years ago and just haven't gotten around to redoing it due to the drain situation. The house was build in 1962, so I have some galvanized drain pipes and this shower appears to have a brass drain with a rusty old pipe that I'd like to replace. You can see I tried chipping away with a chisel and hammer and was getting nowhere fast. I want to rent a 20 lb demo hammer from home depot and try and chip away the concrete and make a 12" hole around the drain center. I'm concerned that I might damage the pipe beyond where it elbows 18" below the surface. I'd like to use a kerdi drain and system for reference.
Pictures of shower and drain: https://imgur.com/a/SnoUb
Questions I have:
1.) For removing and replacing the drain, is a demo hammer the way to go? I've never removed concrete, so is this something I should hire a plumber for, or is it simple enough for a DIY'er to do with a hammer and then Fernco couple PVC to the galvanized pipe? Do I need to scope the drain to see how bad the corrosion is downstream? I've poured water into the trap and plugged it for 2 years with a towel, and it appears to still have water at the bottom so hopefully it isn't leaking. I haven't tested the flow rate to see how quickly it drains, though. The main stack vent/drain is about 5 feet away. The drain goes into the concrete floor along that curb, which is a wall between this bathroom and the adjacent utility room. I'd think replacing the drain to the main stack would involve some serious demo, so I'd like to replace the drain correctly without making this a huge undertaking for myself.
2.) I'm replacing the manifold with a Hansgrohe iBox. I'm still using a standard single shower head, so it should be straightforward. Is this a DIY job or should I hire a plumber to install? I've only sweated copper pipes once before, but I could learn and would think any issues would be apparent right away.
3.) I'm guessing there isn't a liner underneath the concrete pan, so should I just raise the drain and use a preformed shower pan?
Thanks in advance.
Questions I have:
Thanks in advance.
