mbailey5
I want to rebuild my 2nd floor master shower with a digital shower control system and multiple heads/jets. The current feed is a single 1/2" copper line. The pressure at the shower head with the valve halfway between cold and hot is 32 pounds. However, if a sink faucet anywhere in the house is turned on, the shower head pressure drops to 24 pounds. If a toilet is flushed with no faucets on, the pressure at the shower head drops to 20 pounds. The existing shower suffers from temperature changes when other faucets are in use. The house was built in 1994, the water heater was replaced in 2012, and I have a water softener installed where I the water line enters the house. How can I determine why such large pressure changes occur and whether a larger shower supply line must be run to allow the new system to be installed?
