Xiaotian Guo
Hi,
I just finished my guest room demolition for a gut remodel. After opened the damaged subfloor above standing shower, I found that the ABS drain pipe has no slope, I put a torpedo level on it and it's dead center
The level drain pipe(OD 2.5) is about 1 foot long between the P-Trap and sanitary tee. To replace it would significantly increase the scope of my project, I assume I will have to do the following to fix it:
- Cut the vent pipe above the bottom plate.
- Open the wall (another bathroom, tiled shower wall) downstairs. cut the section
- Remove the sanitary tee between the ceiling and floor, the drain pipe in question and p-trap
- Reconnect everything and make sure the slope is right.
I could ignore this and do nothing about it, but I am worried I will waste the opportunity to fix a major issue I have had with this bathroom - before the demo, since I moved to this house, the shower had a urine smell after the shower, if I stop using the shower for a while it would go away. There wasn't any clogging issue, just the smell after shower. I did some research and suspected it's either vent pipe clogged. or the drain opening has accumulated some very nasty gunk - and give off the smell when heated by warm water - the drain cover was glued on with epoxy so I could not open and clean it. But after I discovered the slope issue, I started to think that might have something to do with it.
I'd really appreciate any advice or suggestions.
