DIY-Ken
- Messages
- 7
- Reaction score
- 0
- Points
- 0
I recently replaced a leaking plastic fitting on Polybuteline pipe with a sharkbite fitting. This is the second plastic fitting to leak in this past year so I decided to go ahead and replace every fitting I could get to in the attic at least. It seems to be holding fine but should I have any concern about the sharkbite fittings pulling loose over time?
I recently had a plumber tell me I should have used compression fittings instead but I was told by the guy at HD that I should not use compression fittings on PB pipe. Help! After reading a bit on the internet I don't see any real negative comments on sharkbite other than the cost. Should I be worried about this now? Should I consider replacing these sharkbite fittings with compression fittings instead?
I ran into problems using a compression fitting toilet shutoff value on the PB pipe sticking out of the wall so am not too keen on using compression on this PB pipe either. At least not the simple kind involving just tightening the fitting down over the brass ring. I never could get this to work leak free on that PB pipe. I finally had to call a plumber in and he used a crimper tool to put the brass ring on.
Any advice would be greatly appreciated.
