Shallow Well/Prime Issue?
Tomnet
Michigan
Been helping my son install a well for irrigation issues. We have hit good water, at about 20 to 22 feet,, whne we check in the line we have 7" 6" of standing water. The problem is we can not get the pump to draw the water up no matter what we do! We sand sucked the well with a 3" pipe, and then dropped a 2" pipe with the point down inside, and pulled the 3" back up to espose the full point. Do we need to completely pull the 3" out? Is it posible we are losing suction through it some how? The pump is located dirtectly over the well.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
We have hit good water, at about 20 to 22 feet,, whne we check in the line we have 7" 6" of standing water...
I assume you meant 7 feet 6 inches. Anyway, as Porky said you might not really be in a water bearing aquifer. How did you determine that you "hit good water"?
How long is the sandpoint? 7 feet of water is not much if your sandpoint is 4 feet long. A small cone of depression will have you sucking air.
Tomnet
Michigan
Thanks for the responses! Yes I did mean 7 feet 6 inches. Our point is 4' as you indicated, so sounds like we need to go deeper. Being new at this, we basically though we had hit good water when we were drawing a "slurry" that was basically more water then sand.
