I have a shallow well, the 94L105 pump is about 18 years old, the point has been in the ground longer than that. Recently it started running constantly just a few lbs before being up to pressure. I put a new pressure switch on it and it the issue went away for a couple weeks but it's back again. It's set right now to cut off at about 40lbs.
I plan to replace the point (it's past due, I'm sure) but the pump has been getting pretty warm (not quite hot, but with winter ground water even warm is a big change) and I'm wondering if I should be thinking about replacing pump parts at the same time I have the water off in the house - impeller, etc. Also, where would the best place to order the parts be?
