Sewage Pit
CanadianSal
ontario
My home sits on a Septic System. The basement has a roughed in Toilet and Shower. In searching for the Pit, I found it in the next room - concreted over and unmarked. This house is about 30 years old. I finally found the hollow spot and found the pit.
Its filled with Water. The Water actually rises and falls - I am assuming that this dissipates under the foundation f the house?
My question is - if I install the Sewage Bin and the Ejector pump, do I need to install a sump pump in the same pit? So I will need to fit 2 bins side by side in the same pit?
I am assuming that there should have been a sump pump in that pit all along. I have set up a temporary put to get the water out, but my main goal is to install the toilet and Shower - so I will need the ejector pump installed. Thoughts on how to manage this?
Sal
Normally to catch the ground water, you have a trench or pit gravel lined with a sump pump to the outside. That pump can have a 1.5" line with check valve.
The sewage ejector needs to be tight and contained to prevent odors. It will need a 2"pipe with check valve and shutoff leading to a 4" if you have it, or at least a 3".
The sewage pump also needs a 2" vent to the air through the roof.
CanadianSal
ontario
Thank you. Does this mean that i will have to dig adjacent separate pit to catch the water? I am new to this, and I was assuming that perhaps, I can dig the pit deeper and install a submersible pump under the basin? this way everything can be sealed? I am guessing this is not correct?
And I saw somewhere on the forum that Putting holes in the basin is not a good idea either.
If it were a septic pit, it would contain stuff that would not usually be described as water. Were you being overly delicate when you said water? You might have a water cistern or even a well in the basement, and the septic tank is out in the yard. Follow the sewer pipes in the basement. Where do they point to?
