Setting well pump in new drilled well
joe lesperance
prince george, BC
Hi ,
I have 400 ft drilled well .Static level is 120 , I have 1.5 hp pump. Well produces 2 gal. per min. Any suggestions on how deep to set the pump ? I have had someone say 380 ft , but concerned about sediment issue. any advice would be great. Thanks in advance !
What diameter is the well? A flow inducer can help things including sediment that might fall from above.
20 ft off of the bottom is usually considered to be a good number, and leaves considerable room for sediment.
Is that a 10 gpm 1.5 HP pump?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Like Reach says 20' off the bottom should be fine if you can use a flow inducer. With a static of 120', even setting the pump at 300' will give you about 270 gallons stored in the well, which should be plenty.
