I just bought a small ranch in Chesapeake VA. I have two shallow wells on the ranch that provide all my water. One of the wells supplies my house. It has a large pressure tank and a Sears Model well pump. The pump says Pressure 20/40, Model 390 25150, Code E82B. There is a small metal box on the side of the pump motor that is connected to 110VAC and has an air line going to the actual pump (I'm assuming this is a control box or air injector?). The control box has two screw adjustments that are inside springs. I'm assuming these are the air or on/off adjustments. One screw is larger & longer than the other.
I'm writing because I have a problem with surging & fading water pressure in my house (when I flush the toilet, run the shower, run the sink, etc.). I watched the pump & pressure tank pressure valve while the water was running and noticed the pump would cycle on as the pressure fell to around 26 lbs, then off when the pressure read 56 lbs. Then the pressure would fall very quickly (as water flowed) and the pump would cycle on again. It's like that constantly, on-off-on-off-on-off, etc. (cycles about every 5-10 seconds). When I turn the water off the pressure does not fall and the pump does not cycle, so I don't think I have a leaky tank or bladder. What I would like to happen is for the pump to turn on when the pressure tank drops to a certain pressure, run the pressure back up to a sufficiently high pressure, and stay on at the fixed pressure while the water is running, then turn off once the water has been turned off and the tank has pressured to the shut-off pressure. Isn't that how it's supposed to work?
I had a plumber out to check the pump & pressure tank and he said they were both fine, but that I needed to adjust the on/off controls using the screws. He said that vibration from the pump motor sometimes caused them to back out over time. He did a quick adjust and it seemed to make the situation a little better, but then a few days later it started again. He did not explain the correct process for adjusting/setting the control box and I do not have an owner's manual for the pump.
Does it sound like my pump/pressure tank are operating correctly and just need settings adjusted? If so, what is the correct process for setting the on/off screws on the pump? Why are there two adjusting screws (which does what) and which should I be turning? Which is the correct way to turn the screws, clockwise or counter-clockwise and what is the impact of turning in each direction?
Please help!
Please help!
