Seal Compression Cap?
GoDillos
California
I am removing a sink and trying to cap off the copper supply line. I have easy access to where it branches off, and it uses a compression tee there. I think the cleanest thing would be to just undo it's branch from the compression fitting and put what I've seen called a "compression cap" on the threaded connection there.
I understand that a a normal compression fitting uses the ferrule to seal. But, how do these end caps work when there's no pipe underneath them? Do I need to use tape or dope? Do I put a washer under there?
Thanks
cap
They make compression caps that screw onto the tee, but their success rate at not leaking is not very good. Cutting a washer to fit inside may help it seal better.
Furd
Engineer
Wet side of Washington State
I tried using just the compression caps and they leaked. I cut some rubber discs (used an arch punch) and they sealed quite well.
I do not recommend using pipe sealant on anything but tapered pipe threads.
SaidWhatWhen
San Jose CA
Thanks Terry. BTW, for others, the flat washer for 3/8 compression end cap is Size 0 or 17/32" which I bought at Ace Hardware. Danco mfg Stk #35063B.
