Mike Nottingham
Hello everyone, hopefully someone can help me out here ive been struggling with this for a while. I have a shallow sandpoint well, we recently moved but are going to try to put the place up for sale. Since no one is living there we aren't running much water. the pump ended up going bad a few weeks ago so i replaced it with a new one but couldn't get it to pump water. I pulled the casing and replaced the sandpoint filter, couplers and unions along with the check valve and it worked well until it sat again. Once i messed with it for a while i would be able to get it to draw water again but somethings still not right, i should be able to turn it on and be good to go. Today i tried it out again with no luck until i drained the holding tank, then the well pumped up on its own with ease. But once again if it sits for a day or two i have to restart the process. I thought at first somehow there's air getting in the system somehow but i double checked every fitting and taped the threads well before installing for the third time. What i'm guessing or thinking is the pressure in the holding tank is greater than what the pump is actually pumping which isn't allowing the pump to draw water until the pressure is lower. Is this correct or does anyone know how to fix this issue? Any help or advice is much appreciated.
