Flapper
Last year I found some minor leaks at that gate valve, but didn't fix it as it would require rebuilding this whole thing.
Today I took a look at it and discovered that it had gotten worse. Now there's a hissing sound, which I thought was coming from the leaking valve until I dug into the ground. Turns out there's a much worse leak in the ground, making a hissing sound and saturating the area.
Also, the RPZ assembly has started leaking from the vent. It did a little while ago but I fixed it (somewhat) by purging it to open the vent. I found it dripping again and it won't stop dripping.
This galvanized pipe loop needs to be rebuilt as soon as possible, from the meter to where it connects to the polyethylene supply line (somewhere underground nearby). We'll get a new PRV but I'd like to reuse the RPZ, though because it's leaking and isn't lead free, we may have to replace it too.
Questions:
- This is a highly critical part--leak is before backflow preventer and PRV; very high pressire (175PSI last I checked). What regulations (in California) apply to this?
We may need some kind of temporary bypass until and during the rebuild. Can that be done? Recommendations?(already done)- I reckon it is going to have to be remade with copper, but I'd much rather use PVC if I can. What methods are available?
- What would you do in this situation?
