Replacing PVC drain pipe for washer
Well I dont want you to feel bad it looks a little hokey but if its not getting covered and you put some support like plumbers tape and it has no weight to speak of on the joints I dont see the harm but if you are enclosing it id definately replace.
those arent approoved in that location , using shielded couplings is absolutely ok
imaltesers
New York upstate
I picked up one of these but it seems to be too small for the pipe. Is this the right one? Also there's a stop in the middle so I can't slip the whole thing on the pipe and slide it back over once in place (that's what I did for the other Fernco coupling). Any tips on how to get this one on?
Not planning to cover this anytime soon. I got some strap supports to wrap around the pipe and nail on the joists/ceiling. Where would I use the plumbers tape? Thanks for the feedback
wwhitney
Berkeley, CA
The 3000-33 is for 3" CI to 3" Plastic, you should see one side is smaller than the other and has some raised text on the inside saying CI. For 3" Plastic to 3" Plastic, you need 3005-33.
See here for more info:
On installing the couplings, the pipes should be cut so there is an 1/8" to 3/16" gap between the plastic ends for the rubber stop. Then you slip the rubber on one end and roll the open end back over the installed end so that the second pipe can be moved into position. Then unroll the rubber and slide the shield into place to install.
Cheers, Wayne
Liquid dishwashing detergent can be used to lubricate for easier sliding.
imaltesers
New York upstate
Thanks for all the tips. The local box stores don't have the 3005-33 in stock so I need to travel further over the weekend. Will get to replacement after that.
they arent as common sure seen a million regular no hub couplings used for this but those are incorrect. never seen a shieled coupling 3 inch plastic to plastic at a home depot but havent looked either
