I have 2 four inch schedule 40 PVC pipes running horizontal into a 4 inch double wye with a clean out going through a ten inch poured wall to the septic. The wye is leaking inside the wall back into the basement and when I look in the clean out I can see the pipe into the wye is on an angle causing the leak. Is the double wye the only fitting to use, from what I read using a tee flat is a no no. I also see a double 1/4 bend but can't find much info and proper position for use. The thing I don't like about installing a new double wye is the fitting is so tall it has to go 4 plus inches into the wall, but if that's the code that's the fix, just looking for any options.
