JuanSigned
My basement tests high for radon so I'm in the process of sealing holes before I install a radon vent fan. The single biggest hole is the sewage sump. My plan is to redo the plumbing to make future maintenance easier and to seal it with something like this:
Here is the current layout:
I have a couple of questions:
- How big does the vent need to be for the sump? The current vent is 2" and is not shared by any other drains. I would like to repurposed the path it takes to be used for the radon vent. (the 2" pipe will be removed and replaced with 4" for radon) Could I use an AAV in this application? (AAV's are approved in my jurisdiction)
- What would you change from the way it installed now?
