Recirculating pump
handyman54
So Cal
Can the flow/check vale be reversed to make the direction of flow go the opposite way and does the arrow on Boky Wox indicate direction of flow? see attached pics
Bannerman
Ontario, Canada
The curved arrow on the end of the motor represents the motor and pump rotation direction.
To change the flow direction, most similar pumps are connected with the motor upside down, then the 4 bolts from the pump body are removed to allow the motor and control switch to be rotated to the correct orientation.
To operate correctly, the motor shaft must be installed horizontally.
handyman54
So Cal
that is what I thought when I looked at the pic. My so called plumber installed it backwards so, I'll have to change it my self. It would be too much trouble to take the motor apart and try to change the flow direction
Bannerman
Ontario, Canada
The motor direction is set to appropriate spin the pump impeller in the correct direction. Spinning a impeller in the opposite direction cannot be just assumed will work correctly.
The most difficult part will be to disconnect the inlet and outlet fittings to rotate the entire pump 180 degrees so it will then flow in the correct direction.
Although the control switch will then be located below the motor, you have the option to either leave it there, or remove the 4-bolts holding the motor to the pump body so you can simply rotate the motor so the switch will be again at the top, then reinstall the 4-bolts.
