Hey folks. Great forum here. I really appreciate having access to as much info as is here, even just lurking.
I have an old 2500 valve (and an irrelevant but as far as I can tell bullet proof 3200 timer) that began to leak externally from the piston / plunger seal. I am preparing to rebuild, and I had a few questions for you all.
Is there an advantage either way to purchasing 60090 & 60121 (metal piston & rubber seals separately) VS 61670 (plastic piston & silicone seal kit)? They are about the same price. My gut tells me I'd rather have a metal piston, but it also tells me I'd rather have silicone seals. My water has very high iron in it, and I feel like this contributes to rusty grit that is heck on seals.
Also, I intend on replacing the brine valve piston assembly (60029) & reusing my BFLC - Does this sound reasonable?
While I'm thinking about this thing, are there any other parts I should replace in this unit? I'd like it refurbed & ready for another 20 years of service.
Thank you for your time folks
Max
Max
