Questions about venting options
Flow&Go
Upstate New York
Hi all,
I am trying to make a bathroom/laundry group in a somewhat challenging garage conversion. I'm hoping that someone can advise me on where the vents should be placed on this system. Normally I'd wet vent it using the toilet, but the placement of this toilet and the limited space I have to place the main drain, have caused me to have the toilet draining above the shower and lav drain on the stack. Do I now have to have individual vents off of the lav and shower? Is there a better way to configure this? Any input is appreciated!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
For sure you can roll off an individual 1.5" vent for the shower and then a normal above floor vent off the laundry drain tee.
wwhitney
Berkeley, CA
Can you use the lav to wet vent the shower? The toilet is obviously vented by the top connection of the san-tee, and the laundry will need it's own vent.
Cheers, Wayne
No sence running extra vents but if its open above its not that much work its pretty much the only way Ive done it. I havent really took advantage of horizontal wet venting. they can all tie in together
